Home > Technical > Restricted performance conundrum
dangermousehouse
Australia
I’m experiencing restricted performance occasionally.
It only seems to happen when the engine is cold and climbing a slight gradient about 1 kilometre after leaving home.
My IID tool doesn’t always pick up a code, but when it does, it’s the P006A MAP correlation.
I’m gonna make a smoke machine and see if there’s any leaks in the air system, but thought I’d ask if anyone else has experienced this, as it’s odd it only happens when cold.
I’ve recently renewed both air inlet manifolds, so hopefully they’re still ok, but did notice some oily smeg around the throttle body Y piece dooberry, suggesting maybe a leak here. Air filter is new and MAP sensor is clean.
Any pointers appreciated. Is the Y piece extraction fairly easy surgery?
Cheers Less is more, more or less
Post #583607 Sat Jul 06 2019 7:23am
Fill in your profile !
2.7 ? 3.0?
Post #583616 Sat Jul 06 2019 9:14am
dangermousehouse
Australia
Dang it. Thought I’d done that already Razz
It’s the 3.0 diesel
I’ve just ragged the bejesus out of it and no restricted performance. However, this morning when it was cold, the alarm appeared Less is more, more or less
Post #583618 Sat Jul 06 2019 9:41am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Read/ google ToPix: LTB00445V3 RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #583630 Sat Jul 06 2019 8:17pm
dangermousehouse
Australia
Thanks for that Hog.
Spent a bit of time on it today and there’s a slight leak from the O ring on the inlet to the throttle body.
Also, the secondary turbo vent hose is snapped.
Is the hose “special” or can it be found at a motor factors?
Post #583641 Sun Jul 07 2019 9:55am
Hog
Welcome! I don't feel that vent hose is special, but I would not take any riskwith these cars. Go for OEM. RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Post #583658 Sun Jul 07 2019 11:56am
