![]() | Home > General > Bolt sheared on rear hub |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
You can certainly buy the studs,,,,,, I was actually surprised how easy they come out. I accidentally hit one with a hammer ( not a Rangerover though) and out it popped, managed to put it back using the wheel nut to pull it back in so you may not even have to take the hub off. 2010 RRS, TDV8
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4509 ![]() ![]() ![]() |
A wheel stud has sheared? |
I guess the wheel being loose caused the stud to shear, cos if not I’d be concerned for the other 4. Thinking about it, I’d be concerned the damage has been done and you may need a new hub to be sure the other studs haven’t developed any stress’s. 2019 5.0 SC SVA (Current)
Silverman Member Since: 25 Apr 2019 Location: London Posts: 30 ![]() ![]() ![]() |
Yes that’s exactly what happened. I heard a knocking and when I inspected the studs weren’t tight.
& check the wheel because the holes could now be elongated & if they are & you put the wheel back on they will loosen again Andy.
No way to fit a rear stud without pressing the hub out of the bearing
In that case I’d put a new hub, bearing and probably a brake backing plate on at the same time. 2019 5.0 SC SVA (Current)
Sorry, double post. 2019 5.0 SC SVA (Current)
