Home > Maintenance & Modifications > Battery and fan
JohnBlueSport
United Kingdom 2007 Range Rover Sport TDV6 S Buckingham Blue
Battery and fan
Hi, Has anyone fitted a dual battery and charging system to the First generation (l320) RRS, also changed from viscous fan to an electric one like Kenelowe
Post #583194 Fri Jun 28 2019 12:19pm
Buckster
Dual battery with a split charge should be very easy to do on the early first generation L320 as the space for the second battery is already there with nothing in the way like the later facelift cars.
Believe you will also need a left hand drive battery clamp that can be brought from Land Rover.
You best bet is to become a member of Disco3.co.uk which is the sister site to here and use the search facility for split charge systems and 2nd battery installations as it’s exactly the same as early sports Thumbs Up
Oh and welcome to the forum Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #583197 Fri Jun 28 2019 1:26pm
Why would you want an electric fan?
Post #583200 Fri Jun 28 2019 3:33pm
If you haven't already figured it out, the space for the second battery mentioned by Buckster is adjacent to the brake master cylinder. 2012 SDV6 - it's missing a couple of cylinders
Post #583201 Fri Jun 28 2019 3:41pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
You already have an electric viscous fan, speed controlled by ecm.
On one of my P38's I've built in a thermostat to engage the the aircon fans when viscous struggle, but on the RRS LR have done the job from factory, although in the same fan, why would you need more? is it the blistering hot weather i Scotland Cool
Post #583204 Fri Jun 28 2019 5:10pm
JohnBlueSport
Thanks for this look into it, First time with newer stuff RRS , Previously was Disco 1 and 2 , so big jump for me
Post #583205 Fri Jun 28 2019 5:20pm
JohnBlueSport
Yeah Coming from D2, Not used to all these plastic covers lol
Post #583206 Fri Jun 28 2019 5:21pm
JohnBlueSport
Ok thanks New to all this coming from D2 and D1,
Post #583207 Fri Jun 28 2019 5:23pm
JohnBlueSport
Thought it would benefit, but learned that they already have so can scrap that idea.
Post #583208 Fri Jun 28 2019 5:24pm
rover75
You should download the workshop manual, if curious about stuff and DIY minded.
can't remember where, but it's on the forum and some members have it in their signature to grab
Post #583210 Fri Jun 28 2019 5:42pm
Find a post from forum member naks and the manual is linked in his signature. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #583211 Fri Jun 28 2019 6:11pm
