Home > Maintenance & Modifications > Rear brake backplates
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi lads
Think I will need to change my rear brake backplates starting to get quite corroded . How easy are these to do and any hints tips on how to do them would be appreciated.
I have seen the video of British Atlantic showing split plates so the rear hubs don’t have to be removed.
Is this an option has anyone replaced them this way.
I have heard that when changing them if you disturb the rear wheel bearings they will probably need replaced.
Any help advice would be appreciated.
Cheers Jock Thumbs Up
Post #583175 Thu Jun 27 2019 10:10pm
Disco_Mikey
To fit the one piece ones, the wheel bearings do need split and replaced
You will need a hefty press for them
Post #583181 Fri Jun 28 2019 5:45am
Jock 77
Cheers Mikey much appreciated.
I will probably be in touch bud.
Cheers Jock Confused
Post #583196 Fri Jun 28 2019 12:25pm
