Home > Maintenance & Modifications > Longer shocks & airbags
Hi everyone,
After seeing how a D5 goes higher when off-road compared to the RRS, how difficult would it be to do the following:
1. replace the airbags with longer ones
2. replace the shocks with longer travel ones
or is this a stupid idea? --
Post #582934 Mon Jun 24 2019 8:57am
Disco_Mikey
Doesn't the D3/4 have longer travel shocks than the Sport?
Post #582942 Mon Jun 24 2019 12:58pm
Not sure, but will they even fit, since the L494 and D3/4 are on different platforms?
Wouldn't the D5's stuff be a closer fit since they're on the same platform? --
Post #582992 Tue Jun 25 2019 9:06am
HughN
Wales
I have an EasyLift box on my L320: with standard 'off-road' setting plus 55 mm from the EasyLift, the wheels have started to noticeably 'tuck under' when viewed from the rear. This effect could well be more of a limiting factor than the practicalities.
Post #583004 Tue Jun 25 2019 11:53am
The RRS1 shares arms with the D3/4 so if the D3/4 wheels can do it, there's no reason why the RRS1 can't. Could swapping D3/4 struts on to an RRS1 allow the extra movement?
Likewise, the D5 shares arms with the RRS2 (according to Advanced Factors's site, the same item is available for both vehicles). Does the D5 have the same variable dampers as fitted to the RRS2? If not, swapping the struts may require some reprogramming to stop the relevant ECU having a tantrum when it can't find the correct dampers. 2012 SDV6 - it's missing a couple of cylinders
Post #583007 Tue Jun 25 2019 12:23pm
yeah, I think the variable dampers will be the issue here - I don't think the D5 has them. --
Post #583047 Wed Jun 26 2019 8:18am
