Home > Maintenance & Modifications > crankshaft diy removal
tony waterman
Hi All
i have a 2011 rrs 3l tdv6 and i have been told the crankshaft has seized, i have also been told that it is not possible to do it yourself as the camshaft has to be heated up to get it out, i was hoping to be able to get underneath and drop it out from there etc. so basically is it a diy job or not. thanks
tony
Post #582887 Sun Jun 23 2019 12:14pm
tony waterman
sorry made a mistake i am referring to the crankshaft not the camshaft
Post #582898 Sun Jun 23 2019 4:20pm
well you need to disconnect it from the gearbox.
and disconnect it the other end (remove oil pump?)
Undo many bolts holding it in.
The trouble is the crank breaking usually scraps the engine block so little point
Post #582901 Sun Jun 23 2019 5:15pm
tony waterman
excuse my ignorance but if it is just the crankshaft that has gone and there is no other sign of damage how does it scrap the engine.
Post #582908 Sun Jun 23 2019 6:46pm
I think you would be lucky if that was the case
Post #582912 Sun Jun 23 2019 8:18pm
Disco_Mikey
It warps the block...
Post #582913 Sun Jun 23 2019 8:39pm
tony waterman
ok thank for the replies looks like its a replacement engine then.
Post #582936 Mon Jun 24 2019 10:01am
Brit Plumber
There’s some photos on here or Disco 4 site from a independent showing a section of engine block sheared off inside after a crank shaft fail. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #582995 Tue Jun 25 2019 10:06am
tony waterman
thanks i will have a look, tbh i was hoping it was just a case of the shells slipping as this is a known fault, at some stage i will get underneath and take the sump off and have a look and you never know i might be lucky.
Post #582998 Tue Jun 25 2019 10:37am
Brit Plumber
Always worth a look mate, I would take it apart out of interest alone. 2019 5.0 SC SVA (Current)
Post #583003 Tue Jun 25 2019 11:52am
They have an upper and lower sump.
To remove the upper sump you need to remove the fan, fan cowling, aux belt tensioner. (to slide foward and up)
Pull dip stick tube out (where fitted), undo some steering pipes...
PM this guy. I'm sure he will give you some prices/info.
He had his 3.0 engine reconned.
https://www.rrsport.co.uk/forum/member-knwatkins.html
Post #583006 Tue Jun 25 2019 12:06pm
knwatkins
As Mike says, the blocks can warp on these engines when the cranks snap. There have been numerous reports of snapped cranks being replaced along with new bearings then shortly after - bang, it goes again.
Make sure to get all injectors tested because this could be the root cause. Out of spec injector = engine imbalance = spun bearing = snapped crank Kev
Post #583008 Tue Jun 25 2019 12:43pm
you would recommend oval auto's wouldn't you ?
Post #583018 Tue Jun 25 2019 5:13pm
knwatkins
Yes, I used Oval Autos and they were great. The engine is very smooth running. Kev
Post #583019 Tue Jun 25 2019 5:17pm
tony waterman
i think its a trip to halfords for a manual first, i have no choice but to try and do this myself, i was 2 days away from px this car for a 2016 hse when this happened so i still went ahead with the purchase and i only had it 2 weeks when it was stolen, it was recovered but was a write off due to a high speed police chase and i got left 12k out of pocket because of no gap insurance which i had never heard of so at the moment i am still paying for a car i dont have and now my only option is to try and get this one back on the road for as little money as possible.
Post #583033 Tue Jun 25 2019 10:18pm
