Home > General > Considering this as an upgrade, your thoughts please. |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 123 |
Thanks for the tips RRSTDV8, how do I check the headlight issue as I’ve no experience of this, same with the dynamic bits and cruise ?
Fri Jun 21 2019 6:25am |
It hasn't got adaptive cruise despite the advert However it does have dynamic response, not sure about dynamic mode on the terrain dial however. It's a genuine 1 owner with 71k on it, taking the Mrs to view it tomorrow and hopefully take the plunge on it. |
Fri Jun 21 2019 3:25pm |
Thanks Tim I think it does have the dynamic setting on the dial. |
Fri Jun 21 2019 9:39pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
Tim is right. Wouldn't be without dynamic. Especially fast cross country roads. Allows the full performance to be exploited especially when in S mode at the same time, which holds gears longer and has better downshifting and brake effevt when you use your brakes. |
Sun Jun 23 2019 10:25am |
AW8 Member Since: 26 Mar 2018 Location: Sussex Posts: 60 |
Just factor in the potential coat outlay if the ARC dynamic suspension fails or needs attention. I don't doubt the capability of same but I have heard of some big billls sorting ssme. |
Mon Jun 24 2019 12:24am |
All bits are expensive on the RRS. As an example you don't have the option not to have 2 turbos on a SDV6. But when they let go its at least 4k to sort as I know from bitter experience. I am not the only one on the forum with that experience. Dynamic can also be costly to repair at around half that. But the flip side is you are much more likely to hear about failures on a forum than non issues or good stuff so that should be factored in. |
Mon Jun 24 2019 6:59am |
I've left a deposit on the 2010 3.0TDV6, hopefully pick it up on Monday. Looking forward to the upgrades from the 2.7 especially the interior and the power upgrade. Thanks for your input |
Tue Jun 25 2019 10:13am |
