Home > General > water leaking in to passenger side floor
ashleighash
United Kingdom 2005 Range Rover Sport TDV6 S Java Black
hi guys but of advice i keep finding passenger side carpet footwell soaked i had an issue before where water level light kept coming on and i had same problem had to keep topping up water then got that fixed but still having wet and passenger side vents no heat coming through im lost as to what to do next i have a 2005 2.7 tdc sport had the water pump repaced
Post #582537 Sun Jun 16 2019 11:48am
SRE
Spain
Loads of help available on here, however a little basic info might help, for example:-
What year Question
What model Question
Is the car still under warranty Question
What repairs have been done that you know of Question In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #582540 Sun Jun 16 2019 1:01pm
Disco_Mikey
Do you have a sunroof?
Post #582541 Sun Jun 16 2019 2:54pm
ashleighash
yes but not leaking from there
Post #582554 Sun Jun 16 2019 7:22pm
SRE
Spain
Are the sunroof drain tubes clear Question In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #582564 Mon Jun 17 2019 8:52am
SRE
Spain
I think, the drain tubes run down the a posts and exit behind the side vents. you can always remove the side vent and pour some water down the into the drain tube area of the sun roof, measured amount in should equal the measured amount out.
Disco Mikey is the expert, if your lucky, he will be along shortly. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #582565 Mon Jun 17 2019 9:01am
SRE
Spain
Post #582566 Mon Jun 17 2019 9:05am
Brit Plumber
Had my A pillar off last week and I have these drain tubes....and I don’t have a sunroof lol. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #582582 Mon Jun 17 2019 2:28pm
