![]() | Home > In Car Electronics > land rover logo only after incartec kit installed |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
the LR logo means it can't communicate with anything. It has only powered up.
03184 Member Since: 11 Jul 2018 Location: Alicante Posts: 63 ![]() ![]() ![]() |
Hi Andy yes I see 1 red light from nav screen end and other red light coming from old head unit that was disassembled. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
just an update to this, IIDTool is showing some errors, the first im assuming is that i have removed the antenna cable from the loom. The second error Im wondering if could be the cause ????
Can I ask, is the IIDtool is compatible with your new incartec kit |
thats a good question that I have no idea how to answer lol. How would I find that out ?
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
IID Tool would not be "compatible"
good idea. I havent actually ever seen those errors you have aside from the antenna. The head unit was put in about a year ago and works fine apart from the satnav screen. From my recollection the incartec kit only came with basic instructions regarding the actual installation but yes it did come with the old HU teardown which I did. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
[quote="03184"]thats a good question that I have no idea how to answer lol. How would I find that out ?
Antenna circuit fault code is fairly normal. Probably unrelated. |
searching about for the other fault without much success atm RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Steering wheel controls maybe? |
i did note that one of the pins from the SWC had come out and have put back in and steering wheel controls work, will rescan for faults. Just to check now where the link is dying for the satnav RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
update, so didnt realise there was a diagnostic menu that i found on a different forum. Accessing this brings up the sat navigation which works fine. Reading up on what can be tested from the menu to see if it sheds any light. The only thing i found so far was in the MOST test that it shows status zero power.
I can't help think you have done something wrong when taking the radio apart.
