Home > General > Advice purchasing a RRS |
FULL service history would be a starting point. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Thu Jun 13 2019 2:13pm |
Check no engine management lights are on and that they haven’t been blacked out to make you think everything is OK (common trick on cars with EGR problems, it’s amazing what a spot of black gaffer tape or black paint on a lamp can hide)
Thu Jun 13 2019 2:58pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
Do not skimp on the maintenance or servicing, only ever use exactly the right oil, check belts and tensioners done and if not do asap. Accept that these are fabulous cars but expensive to run and you sre going to need to have a maintenace fund to pay for the inevitable bits that will need doing. Find and cultivate a good indy specialist and do not entrust looking after it to a non specialist generalist. |
Fri Jun 14 2019 9:17am |
Cherrymobile1
Fri Jun 14 2019 9:51am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
Check when the timing belts were changed and ensure the water pump was also swapped (cant remember if it was the oil or water pump that fails sorry)
Fri Jun 14 2019 10:03am |
If your new to Range Rover Sports, then test drive as many as you can, you need to get a feel for the car.
Fri Jun 14 2019 12:54pm |
