![]() | Home > In Car Electronics > HK Audio in 2010 facelift HSE |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
The Logic 7 was only standard factory fitment on the A/B's it was a factory option on other models. So would depend on if ordered when vehicle new.
It’s possible to upgrade to Logic 7 with the purchase of a Premium Amp and additional speakers (depending on what you’re upgrading from).
MrGimper Member Since: 05 Jun 2016 Location: Andover Posts: 57 ![]() ![]() ![]() |
Thanks. Most adverts show the Harmon Kardon logo on the speakers. Would this also say Logic 7 underneath if it was a Logic 7 system? I’m trying to determine if vehicles have it before I actually go see them. |
Yes it does, but only use it as a guide and check when you view the car by checking the settings on the screen. 2019 5.0 SC SVA (Current)
Mine has this, have a quick look at rear of headlining should also have a couple of speakers there if logic 7 but someone could always have added them though.
Grrrrrr so most I’ve seen don’t have it from the pics of the speaker grills |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
You get Logic 7 with the HSE Luxury pack... a pack that is well worth having if not getting an AB.
OP was looking at 2009/10 facelift, not sure the HSE Lux existed then or when it was introduced though.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 427 ![]() ![]() ![]() |
I have a HK Logic 7 system installed in my 2010 TDV8 and to be quite frank its really average in sound quality. I don't understand why they call it a premium quality system. I don't know how bad the normal system is, maybe it really bad. |
I rate mine, the source plays a big part in quality. If I play back from a USB it’s ok but playback from a CD or DAB is crystal clear. The Sub isn’t the best but that’s more to do with Land Rover build rather than the HK system. 2019 5.0 SC SVA (Current)
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
Brit plumber is right. Source matters. Lossy mp3s at low bitrate sound crap anywhere and on any system. Cd quality ripped to a hard drive or usb stick as a minimum, no excuses as it is easy to do and storage is cheap.
