Home > Wheels & Tyres > New 22” SVR Viper gloss black alloys fitted. |
MBRRS Member Since: 03 May 2019 Location: Hertfordshire Posts: 29 |
had these fitted
Sun Jun 09 2019 5:51am |
Cheers Andy. Got them for £2.5k with conti sport tyres Brand new gives it a real stance look The name’s Bond ‘ James Bond’ |
Sun Jun 09 2019 7:07am |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Good price that,the tyres alone are near on £300 each if they are the 295/40r22’s which I’m guessing they are,same tyres I’ve got fitted on mine.The only problem I have with the conti’s is they are very noisy,I don’t think I’ll be fitting them again when they wear out,I’m probably going to try the Goodyear Eagle F1’s.
Sun Jun 09 2019 7:16am |
Yeah they are 295/40/22 straight from the dealership!!! The name’s Bond ‘ James Bond’ |
Sun Jun 09 2019 7:17am |
Another thing you could consider is fitting 30mm spacers on the rear it does finish it off nice.
Sun Jun 09 2019 7:18am |
Will that bring them out then. They are wider then my original 22” as they were fitted with 275 I might get the SVR wheel arch extensions. The name’s Bond ‘ James Bond’ |
Sun Jun 09 2019 7:20am |
I’m sure the svr could be 10”wide & mine are 9.5” wide but then again my off set is 45,I don’t know what the off set on the svr wheels is.you could always try the spacers & if they stick out more than the arches you could fit the arch trim,here’s a few pics of my Old SC with the same wheels & spacers.Ive got to admit the all black look looks really nice,it’s just keeping it looking clean is the problem.
Sun Jun 09 2019 7:30am |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 239 |
SVR 22x10 wheels have a 42.5 offset according to LR. |
Sun Jun 09 2019 1:21pm |
So they would need the arch extensions as mine are 9.5 & 45 offset so the svr alloys would stick out 10mm more than mine,unless you got 20mm spacers then you wouldn’t need the arch extensions. Andy.
Sun Jun 09 2019 1:40pm |
Terras14 Member Since: 04 Mar 2018 Location: Singapore Posts: 38 |
The svr rim is 22x10 with offset 42.5. Which means it is 0.5 wider and with a lower offset, it will stick out more.
Fri Oct 18 2019 4:39am |
