Home > Maintenance & Modifications > Anyone changed this filter before ?
Spain 2006 Range Rover Sport TDV6 HSE Santorini Black
After changing compressor a few months back, Im back to yellow suspension fault light. Done all the normal checks, soapy water etc, my IIDTOOL BT is giving the error code: c1131-92 (AF).
Reading the sister site a few posts mention the air inlet filter is sometimes at fault, but cant find a guide on replacing this. Has anyone done this before ? If so easy to do ? Pic of part below and part number: RQB000418 air inlet filter
 RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
RRS 2008 3.6 V8 SILVER/GREY (WIFES XMAS PRESENT)
Post #581848 Tue Jun 04 2019 8:16pm
Isn’t the filter inside the car, behind the left boot panel ?
Post #581859 Tue Jun 04 2019 9:33pm
knwatkins
It certainly is Andy. Kev
Post #581861 Tue Jun 04 2019 10:18pm
03184
ok thanks for the help, I had the spare whell out yesterday and saw the tube from there. The LR diagram sheet didnt show exactly where it rested. Will inspect tomorrow. Does that mean that the filter can be changed without removing the whole thing ? RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #581863 Tue Jun 04 2019 10:28pm
I believe so.
It’s not far from the rear light.
Post #581864 Tue Jun 04 2019 10:48pm
03184
Thanks Andy, will check it out when there's daylight RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #581865 Tue Jun 04 2019 10:49pm
Stevepd
Take photo’s as you go along.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #581868 Wed Jun 05 2019 7:44am
SRE
Spain
01384 (I assume that's your post code El Chaparral)
I assume the new compressor was identical to the original?
There are 2 types of compressor, the original was a Hitachi & AMK being the later. I think you will find it's a straight forward swop, however I believe that a software mod was required, plus a change of relay.
Syd In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #581869 Wed Jun 05 2019 8:39am
03184
Hi SRE, very observant Laughing
The compressor I am guessing was changed before I bought it last year as is AMK type. It was replaced in February with another AMK bought of a "excellent seller" from ebay and replaced by Ilicar in Elche. Ive checked the suspension firmware with IIDTOOL and was confirmed as AMK. Relay was also changed. So after checking most things I'm down to compressor faulty, The air intake filter mentioned in this post or a blockage in the intake itself. Will take photos and keep this post updated. Any other ideas also welcome. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #581873 Wed Jun 05 2019 9:23am
SRE
Spain
Maybe worth joining the sister Forum's, Disco 3 & 4 and use their search functions
http://www.disco3.co.uk/forum/
http://www.disco4.com/forum/
Those guys are more into DIY, as on here we like to just use our cars and polish them Rolling with laughter
SRE In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #581875 Wed Jun 05 2019 10:54am
03184
haha good idea, thanks. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #581876 Wed Jun 05 2019 10:55am
03184
OK, so opened boot removed rear tailgate interior and as Andy predicted, the filter atttached to the body behind the light. Was a Censored to get off. Attched are some photos including the part number nicely printed on the tube going to the filter. Time now to find a supplier in UK/Europe.
*UPDATE* found one new on ebay for 15 pounds, ordered and be here around week or so.
Post #581877 Wed Jun 05 2019 11:16am
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Hi,
to ease the panel install:
http://www.rrsport.co.uk/forum/topic36188.html
Post #581891 Wed Jun 05 2019 5:53pm
03184
Cool Thanks Rover75, came off pretty easy without breaking anything. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #581903 Wed Jun 05 2019 8:58pm
