Home > General > The Thickest Oil Known to Humanity...
RUSK
What's the most viscous oil that I could use in my 2008 RRS without causing issues?
It's a little bit rattly (tappets?) under load, and a local mechanic suggested an oil change with a thicker, good quality oil might quieting it down successfully. I don't want to break it by filling it with honey, but if safe, I'm happy to try it. Idea
Post #581616 Thu May 30 2019 4:47pm
Probably the cam drive chain tensioner needs replacing. Take it to a decent LR indy that knows these vehicles inside out. 2012 SDV6 - it's missing a couple of cylinders
Post #581634 Thu May 30 2019 7:12pm
RUSK
That would be the best solution, however I’m in a fairly remote place with limited regular mechanics, let alone specialists.
At this point I’m keen to try the oil but want to make sure it won’t create more issues...
Post #581711 Sat Jun 01 2019 8:15am
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
I would be surprised if anyone here could give you a definite answer to your question. However, using the wrong grade of oil is a well known way to ruin an engine. My guess is that a thicker oil will not do the job if the problem is as RRSTDV8 suggests.
The days of Putting Duckhams 20W 50 in to sort a noisy engine are long gone. You need to find the reason for the noise and fix it.
Post #581714 Sat Jun 01 2019 9:15am
Father Jack
I'd get the rattle fixed and in no circumstances in any car would I use anything other than the correct specification oil.
Post #581726 Sat Jun 01 2019 11:09am
drdelrrs
Re: The Thickest Oil Known to Humanity...
Using a 'thicker' oil could make it worse (apart from upsetting the oil control rings on the pistons and the con-rod cylinder spray to the bores and piston cooling). The rattle is probably the hydraulic tappets, a thick oil will cause them the 'pump' up prematurely with the potential to cause inlet or exhaust valves to be very slightly open leading to burnt valve/valve seats (evident by popping on the over-run.
As a starter I'd get the engine oil flushed and then use a good quality filter and oil.
Post #581887 Wed Jun 05 2019 3:55pm
