![]() | Home > Maintenance & Modifications > Slight tapping from engine |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
You will need a c1 oil as below. Don't just put any oil in, incorrect oil can contribute to excess smoke.
with the gauge showing minimum (I guess it doesn't show any lower than that)
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
Crikey ! That's low
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
I think you are lucky you still have an engine.
Keep driving around waiting for oil to turn up in the post
Or don't drive it until he gets the correct grade |
Opie do next day delivery. Get the bus or a taxi while waiting. No need to take the risk. |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479 ![]() ![]() |
With the system telling you to add 1.5 litres you still have approx 4.4 litres in the engine,
It would be interesting to know from the op what happens when 1.5l is added |
Absolutely, the system only measures the top 1.5 litres so when it tells you to add that amount you may find it still tells you to add more. In fact you could be running almost dry and it would still tell you to add 1.5 litres.
laurieandsar Member Since: 19 Sep 2018 Location: Yetminster Posts: 7 ![]() ![]() |
Hi all,
So, as said you were “off the bottom of the dip-stick.”
The tapping I think is still there but not sure if it's in my mind now.
