Home > Technical > 2010 RRS Windscreen Wiper (arm) issue
derekmines
So part way through my recent road trip the passenger side wiper arm decided to stop working correctly, if I manually locate the arm on the screen it will perform one wipe and then instead of stopping horizontally as it should it will continue to wipe, off the bottom of the screen and on to the plastic scuttle where it will stop and not work again until I manually relocate it.
The drivers side wiper continues to work perfectly.
Has anyone seen this before / fixed it?
Post #580385 Mon May 06 2019 10:58pm
Will ask the obvious, is the securing nut tight (18Nm.)?
Post #580387 Mon May 06 2019 11:10pm
derekmines
A fair question, it's as tight as I can make it but rusty as anything so I didn't want to use too much force!
Post #580388 Mon May 06 2019 11:14pm
Brit Plumber
Possibly damaged the splines beyond use so it may well be a new arm and maybe pivot if it’s available as a separate part. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580389 Mon May 06 2019 11:19pm
Yeah, might find it's worn away inside the arm especially if it's been slightly in the past and the retaining nut's bottoming out. Spindle/shaft not available separate, new linkage £140.00 from L/R even the arm's stupid money at £40.00 from them, think I might look on fleabay first.
Post #580393 Tue May 07 2019 4:46am
derekmines
That sounds like a sensible course of action, any idea on the part numbers I need to look for.
The car's a late 2009 facelift 3.0 TDV6
Post #580397 Tue May 07 2019 6:55am
I think the arm is DKB500060PMD but may have been superceded by now, linkage was DLS500030 now LR038347 will double check numbers later.
Post #580400 Tue May 07 2019 7:45am
