![]() | Home > Maintenance & Modifications > Removing tow bar |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
if you have removed the lock
As MGO has said, a big drift or drift substitute and a hammer, it will go. 2019 5.0 SC SVA (Current)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
As said, if you take the spare wheel right out of the way you should be able to give the seized pin/shaft a fair wack with a lump hammer and drift.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Thanks chaps. |
