Home > Maintenance & Modifications > 2011 RRS Supercharged Brake Pad Tutorial Videos?
joshuaman
United States 2011 Range Rover Sport Supercharged Java Black
I have a 2011 RRS Supersharged and both front and rear pads have arrived for replacement. I am searching for step by step or video to help me. I have found one for the front on youtube. Not the best but I think I can follow it. but nothing to instruct on the rear pads.
anyone have a write up or step by step I can follow? These are the supercharged Brembo brakes.
Thanks!
Post #579725 Fri Apr 26 2019 10:31pm
Download workshop manual from here, should have all you need.
https://www.mediafire.com/folder/bmioajx5v76k7/RR
Post #579726 Fri Apr 26 2019 10:46pm
Brit Plumber
Rears are TRW on the Supercharged. I’ve just done mine and you only need the WS Manual or Bodsys Brake bible. If you’re doing the discs to, it’s a little more complicated. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #579727 Fri Apr 26 2019 10:55pm
joshuaman
Thanks mates, what does TRW mean? just doing pads this round
Post #579728 Fri Apr 26 2019 11:00pm
TRW is just the make of caliper, unless you already have them might be worth trying to get some EBC redstuff brake pads it will get rid of that annoying light braking squeal they suffer from.
Post #579729 Fri Apr 26 2019 11:11pm
joshuaman
ahh appreciate it. Downloaded the manual. Looks like it will help for the rears. i cant beleive no video of rear pads being done unless they are the same as the non supercharged maybe??? and only the fronts are brembo?
Post #579730 Fri Apr 26 2019 11:15pm
I think the rears are the same procedure as non s/c, I believe the it's just that the s/c may have 365mm rear discs and non s/c are 355mm if I remember correctly.
Post #579731 Fri Apr 26 2019 11:19pm
Brit Plumber
I think Cols got it spot on. I think all models are basically the same, just a different size but the procedure is the same. Pads will take about an hour. 2019 5.0 SC SVA (Current)
Post #579741 Sat Apr 27 2019 8:23am
