Home > Technical > Auto headlights staying on RRS 2010
monkers2003
I’m having a problem with my 2010 Range Rover Sport.
My headlight switch is in the auto position and my headlights stay on in the daylight. They only go off when I select them to off.
The car has been running fine and this has only started the last couple of days.
Any ideas on this?
Thanks
Post #578963 Sun Apr 14 2019 5:04pm
Brit Plumber
How dirty is your windscreen? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #579011 Mon Apr 15 2019 1:11pm
monkers2003
Thanks for the reply.
The windscreen is clean. Washed and wiped it, but still they come on.
Post #579015 Mon Apr 15 2019 3:08pm
be interesting to see if the auto wipers work when it rains.
it's all in the same sensor i think.
Post #579024 Mon Apr 15 2019 6:19pm
geoffsnook
They are the sams senor and it may need resealing to the screen Thumbs Up
Post #579027 Mon Apr 15 2019 7:27pm
monkers2003
So I’ve poured some water over the windscreen and the wipers work. But it seems they just keep wiping after the windscreen is clean.
The lights still stay on as well. 2014 Range Rover Sport TDV6 HSE Dynamic - Causeway Grey
2010 Range Rover Sport Autobiography TDV6 - Stornoway Grey
2005 Range Rover Sport TDV6 - Java Black
1991 Range Rover Classic 200tdi - Roman Bronze
Post #579046 Tue Apr 16 2019 9:38am
I guess what u need to do is position the rear view mirror in the middle. Position.
Then remove the 2 halves of plastic from the rear of the mirror to expose the sensor.
See if it’s glued on fully.
If it is it probably requires replacement.
Post #579055 Tue Apr 16 2019 10:43am
monkers2003
So I’ve removed the mirror housing and checked the sensor. Everything seems fine and all connections are good. I’ve noticed that while I place the wiper is auto mode they wipe intermittently. Even if there’s no water on the screen.
Perhaps this is all linked?
New sensor required maybe? 2014 Range Rover Sport TDV6 HSE Dynamic - Causeway Grey
Post #579066 Tue Apr 16 2019 2:07pm
Arh so maybe it knows the sensor is duff and reverts back to intermittent wipers. and lights on.
A new sensors sounds good. I think there is a fuse. (check your owners manual)
You can plug the sensor in without glueing it to the screen and see if auto lights work (with a torch)
Post #579083 Tue Apr 16 2019 5:20pm
monkers2003
So the car has been to Land Rover garage today as it’s covered by extended warranty.
There are no fault codes and sensor seems to be ok, They seem to think the wire is corroded so is not covered by warranty unfortunately.
Not really sure how an internal wire can get corroded? 2014 Range Rover Sport TDV6 HSE Dynamic - Causeway Grey
Post #579166 Wed Apr 17 2019 8:36pm
Don’t you just love dealers.
So how much they gonna charge you to fix it?
Post #579168 Wed Apr 17 2019 8:42pm
monkers2003
They can’t find any fault so they won’t do any work.
Typical stealers 2014 Range Rover Sport TDV6 HSE Dynamic - Causeway Grey
Post #579169 Wed Apr 17 2019 8:55pm
Brit Plumber
Will they guarantee it WILL fix it? Sounds a bit of a guess to me. Just a thought, how long have you had it? Has it worked before? Has it got a genuine LR front screen. Heard of lots of issues with after market screens not working with some sensors. Big problem on BMWS. 2019 5.0 SC SVA (Current)
Post #579171 Wed Apr 17 2019 9:04pm
monkers2003
Ive had it 2.5yrs. No other problems with it before. It was working up
Until about mid last week. It’s not had a replacement windscreen either.
It’s like it’s just stopped over night.
So frustrating! 2014 Range Rover Sport TDV6 HSE Dynamic - Causeway Grey
Post #579176 Wed Apr 17 2019 9:20pm
Brit Plumber
I’m back home next week so will look at the wiring diagrams. Maybe a bad earth at the base of the A pillar. Have you got a sun roof? 2019 5.0 SC SVA (Current)
Post #579265 Fri Apr 19 2019 5:56pm
