Home > General > Dual screen |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
I’ve done it on my 2012 with the screen and control from a 2013 and I’m pretty sure the 2014 uses the same Gen 2.1 front FCDIM. Does the 2014 have soft keys or hard keys to activate the Dual view? Your manual should show this. You will obviously need a FCDIM (Screen) and change at least 3 files in the CCF. 2012 5.0 SC AB
Sat Apr 06 2019 11:00pm |
Dizzydog Member Since: 03 Apr 2019 Location: Somerset Posts: 6 |
Hi Brit Plumber, according to the manual it’s a soft key,
Sat Apr 06 2019 11:24pm |
FCDIM is Front Control/Display Interface Module. That’s the screen. The L320 has a hard button to select Dual View and a soft Key to exit. If the L494 only has a soft key then it should only need the Dual View FCDIM and the CCF edit, that’s the car configuration file, this file switches on all the options you have and hides what you don’t have. You would need someone with or your own IID tool, VCM2, black box solutions or similar tool to activate. 2012 5.0 SC AB
Sat Apr 06 2019 11:40pm |
Thanks for clarifying that, I’ll try and find somebody locally with a IID , and hopefully the screen will support dual view!
Sat Apr 06 2019 11:51pm |
You’ll need a new screen as they are physically different, the existing screen isn’t capable of dual view so you will need to find a replacement. Can you PM me your VIN and I’ll get you a number to search on eBay. 2012 5.0 SC AB
Sun Apr 07 2019 8:02am |
Cheers for the help Brit Plumber! |
Mon Apr 08 2019 6:14pm |
Rs4-cab Member Since: 01 May 2021 Location: Northampton Posts: 4 |
Hi Brit plumber
Wed May 05 2021 10:10pm |
Install is easy, swop out the FCDIM and the panel, no wiring mods required. The screen is slightly smaller than the standard unit so has its own bezel.
Wed May 05 2021 10:22pm |
