![]() | Home > Technical > what is this.... |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
im going to guess that its a breather of some sort, but have often wondered the same myself. The top part unscrews. I wondered if it was a diff breather for when crossing deep water but could be totally wrong |
I’m sure it’s for getting the engine oil out with a pump. Andy.
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
i was half hoping this is what it was for would be noce to have a little test point to look at the engine oil now and again.... the simple thinks in life ![]() 2012 3.0 SDV6 RRS HSE |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
It’s on a bayonet fitting and is for vacuuming the oil from the sump. Great way to change the oil, it takes about 5 mins to suck it all out with a good vacuum pump and 10 mins to complete the job with new filter too.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
Yeah. Look at ideal place to put some sort of stick down with markings on it. |
Not sure anyone mentioned it being an ideal place to put one but something is better than nothing |
exactly! ![]() 2012 3.0 SDV6 RRS HSE |
good to know... but im happier seeing it flow out the sump plug ![]() 2012 3.0 SDV6 RRS HSE |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
You can see where the pick up point is once your under it. it's next to the sump plug so will extract all but the smallest amount of oil. and as we don't flush the engine oil then what does it matter if a small amount is left.... |
