Home > Technical > Looking for the L320 2010/2012 wiring diagrams
Brit Plumber
Can anyone help me locate the 2010 wiring diagrams? I bought the 2005 to 2009 by accident and it’s of no use.
If I can’t find the diagrams, would anyone know where I could find Soldered Joint 2006 and 2007? They are probably on the medium speed canbus. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #573043 Mon Jan 14 2019 12:37am
What circuit are you on? are those numbers meant to be sj2006 and sj2007? can find the numbers in a few plugs, but just doesn't show where they terminate, just gives destination as sj2006 or sj2007.
Post #573045 Mon Jan 14 2019 12:47am
Brit Plumber
Hi Col, it is SJ2006 and SJ 2007 and it’s the surround camera system. I’ve got the wiring maintenance manual which shows the connector, contacts and destination but the wiring diagram manual I bought with the maintenance manual is for the 05 to 09 car which is of no use. The diagram gives a distance in mm along the wire to where the SJ is from the connector. Which other systems did you find with these joints? It may help locate them, I tried searching the wiring maintenance manual but obviously doesn’t search the diagram, only the titles as it didn’t find any. 2019 5.0 SC SVA (Current)
Post #573051 Mon Jan 14 2019 11:01am
The one's I have just shows plugs and destination as well, they are shown on the parking module and header connectors behind n/s panel in boot, tailgate harness under headlining at top of the tailgate, camera module under drivers seat and also a couple of plugs under centre console. A 6 pin white connector C1000 which they call header-connector behind the l/h panel in the boot shows just soldered joint can bus connections in it, pin 1 is 2006 Y/W and pin 4 is 2007 Y/U if it's of any help.
Post #573056 Mon Jan 14 2019 11:31am
Brit Plumber
Thanks Col, I shall do some invest.
By the way, how did you find which plug destination went to the SJs? Did you check every diagram manually or have a search facility? I couldn’t do a search but I may have missed something. 2019 5.0 SC SVA (Current)
Post #573112 Tue Jan 15 2019 10:07am
devonsteve
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
hi where did you get the wiring diagram for the 2005 to 2009 rrs from, as I have a problem with my central locking not working
steve
Post #573184 Wed Jan 16 2019 5:59am
Chris, I have a Land Rover electrical reference library for the sport, consists of nearly 1200 pages which can be searched if you have a connector number etc. and comes up with location, wire colours, pin configuration and where wires go to etc. honestly can't remember where I got it from, sure I would off downloaded it online somewhere, will have a go and see if I can find it again.
Post #573186 Wed Jan 16 2019 7:11am
