Home > Maintenance & Modifications > Best Screen wash and wiper blades
Buster007
I've recently purchased a L320 Lux Pk which I'm really, really pleased with. On using the washers & wipers the screen started to smear... Big Cry It didn't help it was at night, I literally had to slow right down I couldn't see a thing. I've purchased some new Bosh wiper blades, I was wondering what the best washer fluid is to use that doesn't smear or go jelly like in the bottle to clog the pipes! A friend of mine in the car trade gave me a bottle of Pollytech screenwash I've never heard of it so I'm a bit sceptical about using it?? Cheers Laurence.
Post #572514 Sun Jan 06 2019 8:47pm
Cymruambyth
Wales
I`ve used Decosol as long as I can remember. I`ve tried all sorts over the years but always stuck with Decosol! Steve.
Post #572515 Sun Jan 06 2019 8:53pm
Lindab
Use Gtechniq G5 or Rain X on your screen. The water blows off. An occasional flick wipe with the wiper is all you need at lower speeds. I have been using it for years & don't know the last time I used screen wash or replaced wiper blades. The only annoying thing is when the car comes back from service they leave a bottle of screenwash in the car as they cant top it up Rolling with laughter
Post #572532 Sun Jan 06 2019 11:41pm
Buster007
I got some of that but haven’t used it yet! How’s it best applied? Cheers Laurence.
Post #572534 Mon Jan 07 2019 12:44am
I use Halfords' screen wash, usually the -10degC one. Seems to clean well.
I also use Rain X screen cleaner (rather than the pure Rain X stuff). Again, works well and gives good Rain X performance for a week or so. As I clean the screen regularly, it's no problem that it doesn't last long as it gets topped up regularly. I use Autoglym Fast Glass now and then if there's lots of bug splat on the windscreen. 2012 SDV6 - it's missing a couple of cylinders
Post #572545 Mon Jan 07 2019 11:28am
THe Halfords stuff always used to goto jelly like in the bottle to clog the pipes
Holts stuff gives good performance
Post #572549 Mon Jan 07 2019 1:03pm
Lindab
Make sure your screen is clean. You can clay bar it & wipe with panel wipe. Give the wiper blades a clean too. This may be a bit OCD & you don't have to do this but the main thing is to make sure your screen is clean.
Apply the Rain X all over the DRY screen. I use a paper towel to spread it. Let it dry to a haze then wet a paper towel and wipe it all over the screen, then buff it up with a microfibre towel so your screen is sparkling, then wait till it rains. Up here its about an hour or so Rolling with laughter
I find its really good at night as you don't need the wipers. The quicker you go the faster it blows away. Slow speeds a flick wipe
occasionally
You can use it on all glass, its good on rear window
Post #572550 Mon Jan 07 2019 1:11pm
I've never been a fan of rainX
You have to apply to stuff in such a fussy way.
And when it rains, you get millions of small rain drops on the screen rather than a few large ones.
Refracts the light/vision worse.
Seams a waste of time for me.
Post #572552 Mon Jan 07 2019 1:28pm
Been using it for years and never had a problem. 2012 SDV6 - it's missing a couple of cylinders
Post #572608 Tue Jan 08 2019 5:23pm
Brit Plumber
Re: Best Screen wash and wiper blades
How do you find the Bosh blades? They work well for me but I get annoyed as the driver side just touches the A pillar at the end of its stroke and makes a tapping noise. The reason appears to be the cap on the end which makes it wider than the original. When I get chance, I need to see if the cap is practical or simply for aesthetics. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572632 Tue Jan 08 2019 10:18pm
Father Jack
Unipart screenwash is good in my experience and bosch blades seem to last reasonably well.
Post #572637 Tue Jan 08 2019 10:43pm
Personally I found the Bosch ones crap and noisy so binned them and fitted some Michelin Stealth one's instead.
Post #572641 Tue Jan 08 2019 10:59pm
Father Jack
Maybe you had a bad pair, or perhaps I've just been very lucky with the last half a dozen sets of bosch's ? Quietest I've ever used and no smearing. Downside is they can lift a bit if going 3 figure speeds.
Post #572643 Tue Jan 08 2019 11:03pm
Cymruambyth
Wales
You need to clean your screen properly before applying anything or deciding on screen wash.....using 0000 wire wool. It`ll be like a new screen. Steve.
Post #572671 Wed Jan 09 2019 1:28pm
MrGimper
England 2005 Range Rover Sport TDV6 HSE Zambezi Silver
+1 for Bosch Aerotwin blades. Just fitted another set to mine for the MOT. Never had an issue. Even managed to get Halfords to price match Amazon (they priced £19 per blade and matched to £13 per blade)
Post #574779 Thu Feb 07 2019 7:46pm
