Home > Technical > Starting motor
Andre
Starting motor
Hi everyone
My 05 RRS SPORT HAS TROUBLE STARTING,BATTERY IS SHOWING 12.9v but I believe starting motor so my question is Where is the motor and the best way to access it?
Thankyou
Post #571907 Sat Dec 29 2018 3:01pm
See here and check the relay first:
https://www.disco3.co.uk/forum/broken-down201218-177600.html
STARTER CHANGE
disconnect battery
remove large metal under tray
look under on the drives side of the engine and locate start motor
loosen 1 10mm? bolt which holds the diesel/coolant heater exchanger in place and swing it out the way.
disconnect the 2 wires from the starter. 13mm? and 8mm (the smaller one has a captive nut thankfully.)
loosen the 3? 13mm? starter motor bolts and then remove them and then you need to wriggle the starter out, which can be fun!
The gearbox under tray probably needs to come off too, 4, 10mm bolts
Post #571937 Sat Dec 29 2018 6:35pm
Andre
Thankyou Andy spot on gave starter a good thump car started
Post #571964 Sun Dec 30 2018 1:41am
