Home > Technical > External temperature sensor
Diesel77
France 2010 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Hello , My local mechanic has done the timing belt on my RRS 3.0 TDV6 2010 . Everything is ok but the external temperature sensor shows -39°C . I think it's the lowest temperature possible meaning it's broken or not plugged back.
Somebody knows where is that plug?
Thanks
Post #571444 Fri Dec 21 2018 1:08pm
Black Bess
I would say that you should check everything in the area that he has been working, which will be across the front panel under the bonnet, and also the wiring loom across the rear of the engine. It has to be moved to access the fuel pump drive belt. Check that all the loom connections are pushed together properly.
Post #571455 Fri Dec 21 2018 5:07pm
Black Bess
Post #571456 Fri Dec 21 2018 5:08pm
Diesel77
Thanks , ill do that.I don't know if it's that but after clearing the errors , the temperature went back to normal.
Post #571463 Fri Dec 21 2018 7:07pm
Post #571577 Sun Dec 23 2018 10:34am
