![]() | Home > Maintenance & Modifications > Ghetto-spec FBH remote |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
cool.
| HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651
Hi Andy,
Early cars e.g 2004/2005 will have a red wire coming out of the FBH connector already. So you don't need to purchase the pin, just cut the wire, allowing enough length to join to the wire going into the FBH.
So I can skip the temperature sensor.
No, it carries on regardless.
Hi.
I got it working |
Hi Andy,
Yeah got it working thank you |
As as an experiment, I replaced the RF remote with a wi-fi switch and linked that to Google Home. Saying"OK Google, run the heater" switches it on. |
For those who aren't into DIY.
I see someone has done a GSM SIM version (simple DIY) for £70. TXT your car to start the heater
Got some good use out of mine in March. |
| All times are GMT |
