![]() | Home > General > EGR help |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5127 ![]() ![]() ![]() |
Do you have a petrol still ?
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 ![]() ![]() ![]() |
Can’t believe I missed out the variant!
its not a fun job to remove them on the V6.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
I fitted new when mine failed,, car was undrivable on a cold engine after each failure. EGR valves are not so much of a problem on the V8 compared to the V6 but if you are considering new units do both,, it will save you in the long run. 2010 RRS, TDV8
Thanks for the replies!
I think when problems first started,, but I didn't realise,,, on occasion from startup when cold the engine would be slightly lumpy at tickover but would settle down after a minute or so, also used to get a small amount of whitish smoke from the exhaust. When they failed proper the car had very little acceleration then I would get a restricted performance fault on the dash. Starting from cold their would be clouds of whitish smoke from the exhaust but no power at all,, even struggled trying to get it back on the drive, which has a minute incline,, had to be trailered to my indie, no way I would attempt to drive there.
Mine sounds somewhere in the middle of what you describe. I think I’d likely blank both rather than replace them. It made a world of difference on the car I last did it on. |
At one time it was not possible to blank them on the V8 for whatever reason,, easy on the V6, but I think nowadays some people have done it but I think it requires a software update afterwards. 2010 RRS, TDV8
