Home > Maintenance & Modifications > L320 Sunroof ECU
HughN
Wales
L320 Sunroof ECU
Though the motor drives my sunroof back and forth, it won't do so under the control of the "ECU" attached to the motor. LR want £400 for a new one (motor/ECU combo).
It is:
A Hall-effect sensor...
A 12V relay...
An integrated circuit...
What a rip-off! I'm happy without a sunroof - for £400, I'll employ a punka wallah on the rare occasions I feel like it.
Post #570112 Thu Nov 29 2018 6:57pm
Oldandconfused
Iv'e not used one myself, but there are companies who will repair ECU's for a fraction of the price of a new one. My lad had a repair on the ECU on his Civic type R after which it was fine, albeit his is a rather unsophisticated ek9.
Post #570119 Thu Nov 29 2018 8:03pm
all part sales are a rip off
buy a used one. £50?
Post #570133 Thu Nov 29 2018 10:00pm
Brit Plumber
If you ebay search L320 sunroof motor you’re looking at £200 to £300! If you search FIAT, Renault etc. £30 to £40!!!
https://www.ebay.co.uk/itm/Fiat-Grande-Pun...SwE9pb6Jvf
You’d maybe need to check part numbers or may swop the eprom?
RRS L320
FIAT
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #570149 Thu Nov 29 2018 11:32pm
Brit Plumber
Or a Honda Civic Motor for £25 free p&p
https://www.ebay.co.uk/itm/06-12-HONDA-CIV...SwZJBX~cgb
Post #570152 Thu Nov 29 2018 11:56pm
It will be specific for rr can bus I expect.
Post #570157 Fri Nov 30 2018 12:38am
HughN
Wales
A cunning-plan ruined by reality!
If the ECU was good but the motor kapput this would have been a good route to take. Cheers Thumbs Up
Still, interesting that Webasto do these as well as heaters,
Post #570166 Fri Nov 30 2018 7:19am
Brit Plumber
Could a competent person with the knowledge to download from the chip reprogramme the replacement with the software from the original? The guy on the Disco 3 forum does this with the FFRR L322 clocks into a L320. If it’s £300 versus £30 + a reprogramme it would still be worth it. Maybe even worth just have a spare for the mechanicals. 2019 5.0 SC SVA (Current)
Post #570168 Fri Nov 30 2018 9:22am
what I tend to do with these things, if your cleaver. and I suspect you are!
is disconenct the relay drive coils from the circuit and connect to switch outputs, therefore having a very basic drive to open close the roof.
It will work 24 hours a day, and not good if you have kids as safety bypassed
I do it all within that circuit, so its plug n play. So a replacement can be fitted at a later date if you or new owner find a replacement cheap.
I did this with a renault window motor.
Post #570183 Fri Nov 30 2018 1:41pm
HughN
Wales
^^^good idea.
I did wonder about uploading the firmware to a unit from something cheaper, but suspect it will need some special software to upload it.
Post #570187 Fri Nov 30 2018 2:23pm
HughN
Wales
...can anyone suggest where I might get a wiring diagram / pin-out? I don't have the rights on Topix and Google has let me down.
If not, multimeter, here I come!
Post #570193 Fri Nov 30 2018 3:20pm
switch is negative switch
9 green/white OPEN
8 orange/yellow CLOSE
1 brown/red battery power
10 black earth
3 red LIN-Bus
Post #570198 Fri Nov 30 2018 4:08pm
HughN
Wales
Thumbs Up Thumbs Up
Post #570206 Fri Nov 30 2018 5:57pm
Post #570229 Fri Nov 30 2018 9:18pm
HughN
Wales
Thanks. Thumbs Up Thumbs Up
Post #570231 Fri Nov 30 2018 9:58pm
