Home > Technical > Faulty MAF Sensor
215m3
Faulty MAF Sensor
My 2010 TDV6 is in for the reduced performance fault and they have advised it is a faulty MAF and a failed o ring. Is it worthwhile getting the EGR valve replaced at the same time, even if it is not causing any issues at the moment? Mileage is 53k 2010 3.0 TDV6 RRS Overfinch GTS
1987 BMW E30 M3 2.4 Turbo
1990 BMW E34 M5 3.6 Trackcar
Post #569799 Mon Nov 26 2018 4:41pm
nope. It's not close.
Not sure which of the 3 EGR's your thinking of anyway
Post #569817 Mon Nov 26 2018 9:12pm
Disco_Mikey
3 EGR's? Confused
Post #569820 Mon Nov 26 2018 9:49pm
well the 2 either side.
And that throttle butterfly to limit fresh air, Known as EGR C
Post #569829 Mon Nov 26 2018 10:26pm
Scrumpy
If I were you I'd spend £2.99 on a can of contact cleaner (or MAF cleaner if you can get it) and just clean your MAF sensor first.
It might not work but if all it is is a dirty MAF sensor (very common) it will only have cost you £2.99. 2016 RRS SVR Estoril Blue
Post #569839 Mon Nov 26 2018 11:49pm
215m3
The car is under warranty, so should be fixed under this. 2010 3.0 TDV6 RRS Overfinch GTS
Post #569872 Tue Nov 27 2018 10:18am
