![]() | Home > Faults & Fixes > Low battery / start car |
Mine does the same even after a 2-3 hour drive,,im sure mine is the stop start battery as I never have any probs starting the car & its since I fitted the dash cam.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
I had the same, its the Stop/start battery which is located behind the right hand panel in the boot. Needs a hard pull to open it Have cut & paste my earlier post on it
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 ![]() ![]() |
Had this problem when a Blackvue front and rear dash cam set was professionally installed. Had it removed and replaced by the same installers with a Thinkware set. Problem solved. Blackvue was causing very excessive battery drain for some unknown reason and had same issue with two Blackvue replacements for the original one. |
I have the thinkware & mine is always showing low battery |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
I have the Blackvue and haven't had any issues until now. Was also surprised that after 1 hour 45 minutes driving that the battery would then flash up as being low. Figured it would recharge during that time. Thanks. Will unplug the camera from the fuses in the boot and see if that changes the situation. Although Murphy's law would entail that is when something will happen and a camera would have been useful. 2019 RRS P400e Autobiography 2014 RRS 3.0 TDV6 HSE Dynamic 2006 RRS 2.7 TDV6 HSe Alfa Romeo Guillietta 2.0 JTDM 2011 Mazda 3 1.6 2010 Subaru Impreza 2.0 WRX 2005 |
