![]() | Home > General (L494) > How to check when next service due |
| HXM Member Since: 24 Jun 2018 Location: Up North Posts: 81
Wouldn’t mind knowing myself. First I saw was a message saying service due. MY15.5 HSE - SDV6 - Santorini Black |
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
hi,
| Dogboy Member Since: 07 Oct 2017 Location: Essex Posts: 35
Put the ignition on but don't turn engine over. Press menu, scroll down to the bottom option and it's there with tyre pressures, oil level etc. |
| Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 160
Thanks guys but I definitely do not have that in my service menu - must be as mine is a MY14 that it's different to yours.
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Ive just check my14 ab & it doesn't show when next service due so as you say Punkawallah it must just be on the later models.
| RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439
i dont think you can check when the next service is due - I will check again but I dont think I have ever seen this (MY18 RRS). |
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1922
http://www.ownerinfo.landrover.com/documen...c/G2127804 2026 P460e Autobiography on order
Thanks Jim but this is only for MY16 and later... |
Sure, it was for RRSman who should have that option. 2026 P460e Autobiography on order
I checked this also on mine, it only tells me a service is due on startup. MY15.5 HSE - SDV6 - Santorini Black |
Thanks - my car is currently in for the carplay update and more so wafting around in a Discovery which surprisingly drives quit nicely |
