Home > In Car Electronics > Sat-Nav Cant Use Postcode Search - 2012 RRS
Father Jack
Just do it in one hit. In theory you can leave the stick in situ and start and stop any number of times but mine recommended you did not (contrary to a post above). One hit install worked fine for me.
Post #569273 Tue Nov 20 2018 9:25am
mrluke
IRC last time it was stopping on its own randomly, this time i am ordering my own USB stick as not entirely sure thats a good one .
Just waiting for my usb stick to come and ill give it a whirl.
Post #569344 Wed Nov 21 2018 11:36am
mrluke
Ok drove home and got to 50%
Looks like it does 5% every 8 minutes
On the drive atm awaiting the final 50%
Post #569470 Thu Nov 22 2018 6:47pm
Father Jack
Yes, that was my experience. May get another wee pause but 5% per 8 to 10 mins about right.
Post #569472 Thu Nov 22 2018 7:25pm
mrluke
Took 2:48 mins
No stops , no errors
And the verdict
postcode search now works Bow down
Post #569483 Thu Nov 22 2018 9:44pm
Autobiography1969
Great News,
Glad you got it sorted.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #569489 Thu Nov 22 2018 10:14pm
mrluke
Thanks Wink
Hopefully this thread might help some one else with the same problem
Luke.
Post #569515 Fri Nov 23 2018 9:08am
TubaPlayer
I've just updated mine with the stick ordered from Landrover site and hand the same problem, how did you end up fixing the problem as the stick I have is the latest version 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #569957 Tue Nov 27 2018 10:24pm
mrluke
Sadly the only way for me to fix it was to update it with a newer version (2018), which in your case probably isn't possible.
Are you having the exact same problem as me ? as in after you type in a postcode it comes up with a error ? or is the satnav not letting you type a postcode in at all ( letters or numbers greyed out) ?, if its the later then i imagine as some one has mentioned before in this post that the country is set wrong.
Also did you get any errors or stoppages while updating ?
I would also suggest contacting range rover and explain the problem as you bought it from an authorized site.
Post #569974 Wed Nov 28 2018 9:31am
TubaPlayer
The postcode is greyed out but set to GBR!
There is also no map showing on the screen.
I have contacted the suppliers just waiting for an answer. 2016 Black SDV8 Autobiography
Post #569975 Wed Nov 28 2018 9:35am
mrluke
Sounds like yours got more forked than mine !
I was looking into modifying the current update to be able to run twice, but after a bit of time trying to find out how it detected the version on the unit i kind of gave up.
From what i gaverd all it looks like its doing is copying the files over, so does make me wonder what the data looks like on the HDD and if you can directly place the files on there bypassing the USB interface.
I did read on the Disco forum that its an IDE hard drive inside these units.
Post #569978 Wed Nov 28 2018 9:52am
