Home > In Car Electronics > 2011 RRS HSE 3.0 / TV Not working
iwtts22
England 2011 Range Rover Sport 3.0 TDV6 HSE Alaska White
I have recently purchased the above vehicle which has the TV option but I cannot get a picture at all, not even a fuzzy screen like you would on a normal TV.
Its been brought to my attention that this will be down to the fact that the installed unit is "analogue" which of course has now been switched off and replaced by "Digital"
Is there any easy / cheapish option to upgrade the TV to digital ? I dont really want to replace the existing unit as i am more than happy with it.
Any solutions gratefully received
Thanks
Ian
Post #568540 Thu Nov 08 2018 6:17pm
Brit Plumber
My car is a Sept 11 (2012 MY) and the Tv is digital. Does yours not have both digital and analogue? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #568551 Thu Nov 08 2018 7:48pm
iwtts22
How can I tell ?
Thanks
Post #568556 Thu Nov 08 2018 8:48pm
Should be able to check or change it in the Audio/Video setup screen.
Post #568558 Thu Nov 08 2018 9:16pm
Brit Plumber
You can use topix or if you pass your Vin someone can check it for you.
This is what Topix shows for mine.
Post #568559 Thu Nov 08 2018 9:18pm
geoffsnook
Topix is not always correct though as someone on here has said i believe it say's his has a fridge but it does not Whistle
Post #568560 Thu Nov 08 2018 9:22pm
MY11 cars had Hybrid TV System as standard except the SE variant.
Post #568562 Thu Nov 08 2018 9:28pm
Father Jack
2021 year has digital and analogue tv capability selectable within the menus and as explained in the handbook. Should be same for 2011 ?
Post #568585 Fri Nov 09 2018 9:53am
Brit Plumber
For a 2012 MY this is how I do it, 11MY should be simikar.
Post #568624 Fri Nov 09 2018 3:07pm
Father Jack
Yep, as above
Post #568628 Fri Nov 09 2018 4:31pm
iwtts22
Thanks for the comments everyone
I cannot see anywhere in the manual where it tells you how to switch between analogue and digital
Cheers all
Post #568801 Mon Nov 12 2018 7:14pm
Father Jack
See pics in post above.
Post #568812 Mon Nov 12 2018 10:03pm
iwtts22
My screen is totally different
The pic above looks more modern
Post #568817 Mon Nov 12 2018 10:38pm
The MY12 on vehicles had a different screen interface view to the MY11 but would have thought you had a TV button there somewhere on the older view.
Have you tried this.
TV MENU SELECTION There are 2 methods for selecting single view TV mode. • Press AUDIO VIDEO button. • Select TV or TV/DVD on the Home menu. Note: The TV tuner can receive both analogue and digital TV signals and will maintain the presently tuned channel throughout a journey, subject to reception conditions. In areas of weak reception, you may experience a break-up in picture and sound quality or a blank screen and audio muting. It may be necessary to re-tune the viewed station.
Post #568818 Mon Nov 12 2018 10:42pm
Father Jack
Page 130 of the manual in the 2012my. Have you gone through all of the AV section of your manual ? I don't think there is much difference in AV spec 2011 to 2012 so try another look and you should hopefully see it. AV section is pages 112 to 131 tv bit 129 and 130.
Post #568845 Tue Nov 13 2018 10:44am
