Home > Maintenance & Modifications > Timing belt + new gear box
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
My 2006 Sport VIN SALLSAA146A934562 needs the timing belt changed plus a replacement gear box. I will be on holiday in Spain for a couple of months after Christmas and I'm considering having a local LL Dealership (or Land Rover Garage) quote for carrying out the repairs. I can remember reading some where that when the timing belt is being changed its advisable to change a few other components? So that I can make sure I get a garage to quote for, and change all that is required - I would be grateful if someone out there could let me know what other components should be on my list. Thanks in advance. Andrew Andrew Kennedy
Post #568537 Thu Nov 08 2018 5:25pm
Disco_Mikey
Oil pump when doing belts
Don't expect much change from 4k though Shocked
Post #568548 Thu Nov 08 2018 7:11pm
andrew kennedy
Belt change and gear box
Disco_Mikey…..is that an expected 4k for both gear box and belt change? Thanks for the advice!!! Andrew Kennedy
Post #568564 Thu Nov 08 2018 9:42pm
Disco_Mikey
Yes. Though I'd advise going for a genuine LR box. It's only 200 more than the aftermarket suppliers, but comes with a 2yr unlimited mile warranty Thumbs Up
Post #568570 Thu Nov 08 2018 10:30pm
andrew kennedy
Thanks Mikey for the advice - much appreciated!! Andrew Andrew Kennedy
Post #568612 Fri Nov 09 2018 1:14pm
