![]() | Home > Technical > Hunter Wheel Alignment |
| amgmaj Member Since: 28 Nov 2017 Location: Nottingham Posts: 80
Ok thanks @Tyrefitter |
Just checked I don't think I have dynamic response on my range rover sport 3.0 2010
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
No it doesn’t look like you have,,yours is one of the models I haven’t had,I went straight from a 08 to a 12 plate.
Thanks once again mate |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
That one should be ok if you don’t have dynamic.
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Did they lock it in Tight Tolerance Mode with a plug in diagnostic? If not, then forget it. All air suspension vehicles need putting into TTM for 4 wheel alignment.
Yes software all countries I was next to the screen when he was doing the alignment. Which RRS 2.7, 3.6, 5.0 setting should I go with when I take it back tomorrow if he can't a RRS 3.0 setting? Last edited by amgmaj on Fri Oct 26 2018 8:29pm. Edited 3 times in total |
I put it in TTM myself outside the garage with IID Gap tool |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9156
Yours may have dynamic response. Dynamic response is the name of the hydraulically activated ant roll bars. Dynamic mode is part of the Terrain Response system. Different things, I'm afraid, and often confused even on here.
Wot he said ^^ |
| Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200
I had my castor/camber/toe done on a Hunter machine last week, as it seemed to be pulling to the left slightly, and steering wheel off centre too. This was after I had the lower front suspension arms changed and geometry had been done.
All sorted now steering wheel straight and no pulling towards the left |
Could you please tell me if my RRS has Dynamic response by looking at the pictures of my engine bay?
It’s the big yellow cap in the centre bottom of the second photo. 2019 5.0 SC SVA (Current)
| All times are GMT |
