Home > Maintenance & Modifications > Suspension Fault
Zeoman
Scotland 2006 Range Rover Sport TDV6 HSE Siberian Silver
Suspension Fault
Apologies if this has been covered before. I have been reading up on previous posts and its been very helpful, however, I do have a couple of queries.
I have a 'Normal height only' warning message along with yellow warning symbol.
I do not have access to a scanner, well I do but it wont connect with my sport. So, ride feels normal although I cannot access special programs. Thought, after reading posts, it would be the compressor (Being a 2006 model).
On removing the compressor cover I discovered its been upgraded to the AMK version.
I started up, and the compressor kicked in then went off. I have decided that as I have come this far I may as well replace the dessicant anyway so have removed it. So, after reading posts I am wondering if its the relay? I will order the relay, but where does it go please? And, if anyone has some further wisdom I would be grateful.
Many thanks
Jon
Post #563924 Sat Aug 25 2018 8:43pm
Disco_Mikey
You have either, a worn compressor or a leaking air tank, most likely
An outside option is a height sensor, but the previous suggestions are very common
Post #563934 Sat Aug 25 2018 10:38pm
Zeoman
Thanks Mikey,
I will get a recon kit for compressor. Where can I find the air tank please?
Post #563935 Sat Aug 25 2018 10:48pm
Disco_Mikey
LH side of the chassis, between 2nd +3rd body mounts Thumbs Up
Post #563937 Sat Aug 25 2018 11:08pm
