![]() | Home > Maintenance & Modifications > P2290 fault fuel issue |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Needs a new filter regardless, so easiest and cheapest place to start |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
Update, replaced fuel filter. No change. Can anyone point me in the direction of the lp pump, relay, fuse and where the connector is at the rear of the car please so i can rule that out? Theres no pressure at the lp scraeder valvr at rhe top of the engine bay either. Weird as it drives fine u less foot down. Cheers |
Unable to check rail pressure either as my Gap has decided not to work. |
All you need to know is contained here: https://disco3.co.uk/forum/robbies-guide-l...30062.html |
exactly what i needed. Thanks Mikey |
aghhhh any input on the below Mikey? Brilliant write up Robbie, has helped me lots. My 2006 sport eventually died today. Wont start at all now. I had the 2290 code up. My Gap has also decided to kick the bucket so I cant look at live values. Fuse 1 is fine and has power to both sides on the purge sequence. R8 relay pulls in. I removed the plastic shrowd and push the relay in manually whilst pressing the schraeder. I have no fuel pressure there at all. Censored Was getting no reading at all on amp meter. So my next question is where do i go from here? where do the pump wires run too? and where can i test before I pull the tank off to check the pump? cheers Gareth |
No amps = no current draw = faulty LPFP (usually. Need to drop the tank and check for power/earth at the pump now) |
Problem solved. Whipped the tank off, was suprisingly easy apart from being half full.
Pics to follow. |
Yea flap is fine mate. Guessing could be from anywhere. Flys tho? |
