Home > In Car Electronics > reverse camera
Grizzly_Al
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Galway Green
reverse camera
Hi all,
Is there a way of switching/mirroring the camera view, as at the moment it seems to me to be backwards, it's not got the yellow lines to follow but if it did they would turn the opposite way to what you need Confused Its a 59 plate but seems to be a 2010 model
Many thanks if you can help Smile
Alan
Post #559694 Sun Jun 24 2018 12:25pm
Quite a common fault on the earlier face-lifts, I think you may find you need a replacement camera. You won't have "bendy" yellow lines either unless you have the surround camera system fitted.
Post #559695 Sun Jun 24 2018 12:43pm
Oldandconfused
As Col says, back to front image means camera is u/s (another one for the buyers check-list).
MY2010 was the face-lift model Thumbs Up
Post #559712 Sun Jun 24 2018 3:32pm
Grizzly_Al
Cheers for that,
I'll have to have a look about for a new camera, when I find one do I need to program it into the system or can I just swap it for a new one ?
cheers
Alan
Post #559765 Sun Jun 24 2018 9:47pm
You shouldn't need to programme a new camera, but make sure you get the correct one as there are two different one's, although identical to look at, the standard camera has a 2 pins and a co-ax connection, the surround one has 4 pins and they are not interchangeable.
Surround Camera
Standard Camera
Post #559771 Sun Jun 24 2018 10:31pm
Grizzly_Al
awesome, thanks for that
Alan
Post #559840 Mon Jun 25 2018 7:09pm
