Home > Maintenance & Modifications > Cost of replacing TDV6 Inlet Manifold
JohnHother
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Mine has the usual problem - split and leaking air, causing p006A fault code.
I've just had a quote from Harwoods (main dealer in Hove) -
£2340 + VAT ! Shocked
They use the book time of 9 hours.
Looks like I'll be busy this weekend then. Rolling Eyes
John
Post #559361 Tue Jun 19 2018 11:41am
Disco_Mikey
Only £2k overpriced Shocked
Post #559365 Tue Jun 19 2018 12:36pm
Father Jack
That's horrendously overpriced. Mine went a while back on passenger side as you look at engine with bonnet up. Price was not dissimilar to DM's above when I had it done by the indy I use (working in west mids use Ultimate 4 x 4 Dudley and recommend them for WM dwellers etc). Described as a bit of a fiddly pain in the arse job as you have to dismantle a few bits and bobs to get in and around and change it but no way a 9 hour or body off job.
They're at it ! Take it somewhere else.
Post #559417 Wed Jun 20 2018 12:17am
