![]() | Home > Technical > Rear window wiper |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
the early models have a relay behind the left light. (inside)
Dylan Member Since: 14 Jun 2018 Location: Herts Posts: 13 ![]() ![]() ![]() |
Hi thank you for the reply my rrs is a 2010 facelift .the wiper was working then one day it didn't work then about 20 mins into journey it worked but then didn't work again |
Still worth testing the wiring between body and boot. I had a problem with a BMW where the locks would lock on command but then unlock seconds later. I found that 2 wires had shorted to each other at the point the look hinged. I ended up replacing all the wires at that point as 2 more had split. 2019 5.0 SC SVA (Current)
Thanks for that I will have a look at the weekend |
I have had a diag tool on this and it says open circuit on relay but can anyone tell me the location of it |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
Would appear to still be behind L/H trim panel in boot.
Many thanks for that I will have a look |
Hi all sorry for the delay . I finally managed to get my rear wiper working . The Venter shaft on motor was a bit tight so freed that and was a loose connection on relay so happy days . The relay was as you said behind left panel in boot. Thanks everyone for your help |
Sorry center shaft |
