![]() | Home > Maintenance & Modifications > Different height RRS |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
There are various means of lowering - replacing the height rods, fitting LLAMS height adjustment system, reprogramme height with something like a Gap tool.
dieselwoofer Member Since: 21 May 2018 Location: down south Posts: 23 ![]() ![]() |
These look like standard older cars. does the air suspension sag over time? :wink: 2011 RRS facelift |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
Generally the air either works or drops, they don't ride lower (because the height sensing is separate to the airbags). |
No it does not sag over time - it is deliberate using something as I described above. I run my car at 1" lower than onroad height by using my LLAMs height adjust system. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Does it handle any better an inch lower, or is it just for looks? |
It drives better and is easier to get in and out of.
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Driving or parked?
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
I have a GAP tool, and lowered mine, not by too much I thought, but it lost it's magic carpet ride. When I re-set it to standard, it was sooo much nicer. Not something I'd do again, even for looks. |
