Home > Technical > "rubber" squeak from front when going over speed r
Pinnacle
For the last few days where it's been hot, I've developed a rubber sounding squeak from the front of the vehicle when I got over a speed ramp.
Is this a known common issue. Where should I check first?
Post #555973 Tue May 08 2018 12:03am
Stevepd
Isn't the squeak normally associated with bushes?. Might be wrong and I'm sure somebody will be along soon....
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #555977 Tue May 08 2018 6:49am
Eaters
IIRC some have used silicon grease on the bushes which provides (at least) a temporary cure, And if the squeak goes away then you know what the problem is.
See here - this may help: http://www.rrsport.co.uk/forum/topic41336....queak+wd40 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #555979 Tue May 08 2018 6:55am
Hamtheman
South Africa 2011 Range Rover Sport Supercharged Alaska White
Almost certainly anti roll bar bushes...
Post #555987 Tue May 08 2018 8:51am
