Home > General (L494) > 2018 front and rear lights
Page 3 of 4 <1234>
V8tdi
Wales 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Slightly better pic now she had a bit of a clean up today
Post #544968 Sat Jan 06 2018 5:49pm
highfellzippy
If it has reflectors here then it’s not uk spec
And the indicator doesn’t work on uk cars I tried one on mine and it put the brake light on instead of indicator
Post #545000 Sat Jan 06 2018 10:59pm
Dobby
That's a good point, do the reflectors face rewards? Thats an MOT requirement IIRC, ie, rear red reflectors.
Post #545068 Sun Jan 07 2018 6:20pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Rear reflectors are at the bottom by the exhausts - i.e. don't have to be part of the light lens.
Post #545092 Sun Jan 07 2018 8:00pm
V8tdi
Correct reflectors on uk cars are on the the bumper facing rear wards
Reflectors on the non Uk spec lamps that are being sold on eBay have reflectors on the side I assume either EU or US Spec
You can see here both versions top Uk bottom US EU
I think the important point is if you are going to upgrade a UK spec car check it does Not have the reflectors or it will not work
Both versions are being sold on eBay as plug and play so you could easlly get the wrong part for your car
Post #545103 Sun Jan 07 2018 8:37pm
Dobby
Ah yes, of course. My mistake.
Post #545136 Sun Jan 07 2018 11:37pm
Compulsive
I need the EU spec version with the reflector but I can't find an eBay auction or the part numbers. Any help would be appreciated.
V8tdi wrote:
Got them on eBay but be careful to get uk spec no reflectors
These ones will NOT work you can see the reflectors on them
https://www.ebay.co.uk/itm/New-Range-Rover...0688.m4649
Post #545373 Wed Jan 10 2018 6:00am
andymc
just checked ebay and the last set sold for around 720gbp.
I'll have to wait for a new set to become available as I'm defo in... SVR with a few bits from Urban and Glohh
Post #545450 Wed Jan 10 2018 8:55pm
elaomar
Italy 2013 Range Rover Sport SDV6 HSE Santorini Black
Hello,
Do you have any solution for me ?
I have the version without reflector but when i plug them in everything work good. After 5 minutes, indicators stop working like if the vehicule detect a fault. If i let them few minutes it come back again for few minutes and stop working again
Thank you
Post #550771 Thu Mar 08 2018 12:25pm
V8tdi
Hi
Not sure the reason I did read somewhere when I bought them the My17 was certainly plug and play but no guarantee on earlier models
They work perfectly on mine only issue is the lack of the Audi sweep that obviously is a software issue
I’m not sure if there is a software issue on earlier models although the lamp units look the same
Hope you find a solution as they look great when they work
Post #550794 Thu Mar 08 2018 4:40pm
Ishy16
I have recently done this on my 2017 model. Its simply a plug and play on all models from 2016 onwards. Anything previous uyou need to mess with the pins or buy a cable.
The rear is a simple straight swap and if anyone is looking for any i have a few uk 2018 led spare sets.
THe front requires a new grill bumper and wings. I have brand new set of the front matrix led headlights f anyone wants one to do the conversion. I cannot be bothered to do all the changes hence the sale
I cant upload a photo on this website otherwise i would have shown my car.
Post #554724 Sat Apr 21 2018 10:59pm
Terras14
Hi while the rear is plug and play for my16 onwards, doesnt the front need extensive wiring modification? Also what u meant by wing? R u referring to front bumper?
Post #554727 Sun Apr 22 2018 5:15am
Ishy16
Yes the front lights are different and require a new grill and bumper and I also believe new side wings are necessary. There is also some wiring that needs to be done to.
Post #554736 Sun Apr 22 2018 11:53am
nashvegas
United States 2008 Range Rover Sport Supercharged Zermatt Silver
I have a 2014. What is involved in swapping the rear lights out (I have seen references to "you need resistors" but nothing more than that or specific specs which wires instructions or a how to. Anyone know . ? !)
Post #554802 Mon Apr 23 2018 2:45am
ct83
I like to spend a bit and put this into my new SVR Model 2017.
What is actually the Land Rover selling price at the Dealer?
You want get any failure messages in the car using this?
My location and origin is Germany.
Bye Christoph
Post #557548 Sun May 27 2018 8:55pm
Page 3 of 4 <1234>
