Home > General (L494) > Fuse permanent power dash cam connecting RRS L 494
Bertham
Belgium
I am from Belgium and new on this forum.
Ik have a RRS l494 2017.
I Got as a present a dashcam DOD RC 500s
Can any one help me to find a fuse with constant power in the passenger box, so I can connect the dashcam with permanent power.
The dashcam has protection against battery empty failure with the DP4 Hardware kit.
Thanks in advance
Post #543050 Sun Dec 10 2017 11:00am
MrM
There are some in the fuse box behind the glove box. I am looking to do the same, but only to an ignition live (piggybacking com heating steering wheel fuse). There's also a convenient earth but you will need a 90 degree socket tool to loosen it. Will get my multimeter back out and find a permanent live for you when I next have a fiddle.
Post #543194 Mon Dec 11 2017 6:23pm
Bertham
Belgium
Thanks,
Did You mean fuse nr 43, I wait for your next post.
Post #543211 Mon Dec 11 2017 8:08pm
Farmer Chalk
Bertham, mine is a 16 plate 5.0 so I can’t say they are the same... but I have used fuse 49 as a 5amp permanent positive supply and fuse 52 which is a 10 amp switched ignition supply .... hope this helps...
It is made far easier using an add a fuse connector...however you will need to order the micro versions as they are tiny tiny fuses...good luck!
Post #543213 Mon Dec 11 2017 8:35pm
Bertham
Belgium
Can you tell what is the name of your fuse nr 49, so I can also taken that one in my RRS
Post #543214 Mon Dec 11 2017 8:44pm
Bertham
Belgium
Is it fuse 49 5A "Vehicle immobiliser" for permanet power?
I use the micro 2 fuse in the bypass.
For my DOD I only use permanent power without risk of battery drain.
I will try the 49 today.
Anyway Thank you again for your help.
Post #543235 Tue Dec 12 2017 7:58am
MrM
Bertham, are you sorted now or are you still looking for a source?
Post #543444 Fri Dec 15 2017 3:23pm
Bertham
Belgium
No start this weekend to install.
Post #543446 Fri Dec 15 2017 3:42pm
Eaters
When I installed my Thinkware I took permanent live from the glove box fuse that supplied the horn. Just check your horn works when the key not in. If it does then it’s permanent live
I used a piggy back fuse to connect. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #543463 Fri Dec 15 2017 6:30pm
Bertham
Belgium
Today I found the permanent fuse it s nr. Is 49.
With the help and suggestions on this forum I choose the right one.
Thank you all.
Post #543945 Sat Dec 23 2017 3:49pm
MrM
Good stuff, I used 43 for ignition live (heated steering wheel). Useful info for future ref for anyone looking to fit a dashcam.
Post #543949 Sat Dec 23 2017 4:23pm
Eaters
Glad to hear that you’ve got a good result. And I’m not trying to labour the point, but my reason for choosing the horn fuse (if it’s permanent live on your models) is that it’s very infrequently used and then only briefly. I calculated that taking power from this one would minimise any stress or voltage drop if say you were using your heated steering wheel and dash cam together. It’s probably not a point worth worrying about but that was my thinking anyway Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #544002 Sun Dec 24 2017 6:08pm
MrM
Dashcam power consumption will be very low. Furthermore if there became a fault with the piggyback add a fuse circuit I'd want to know. I use the heated steering wheel more than my horn, so will notice that more quickly. Just my 2 pence worth.
As an side, I'm not sure how people have run the cable up the A pillar, but I've managed to route it above the headlining (so runs diagonally from above the left passenger window and emerges part way out along the top of the windscreen making it very discreet. I used a flexible rod to create the path and then taped the cable to the end of the rod and pulled it through.
Post #544004 Sun Dec 24 2017 6:24pm
Eaters
Good thinking MrM. Thumbs Up
As far as I recall my wire just ran a;; the way down the edge of the windscreen under the headlining and then down behind the A pillar trim, and again left a very neat finish. Not so for the rear camera which I still need to improve. Robin
Gone:
MGZTT 190 2.5
Post #544031 Mon Dec 25 2017 7:40am
