![]() | Home > Maintenance & Modifications > Aircon regas |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Hi Buckster
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5137 ![]() ![]() ![]() |
As a general rule I think it is recommended to have the aircon checked/serviced ever 2 years.
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193 ![]() ![]() ![]() |
My air con was re gassed in January this year, It was pressure tested and I was told it was fine. But the last few days although working it isn't very cold, so there has to be a slight leak somewhere but pressure testing hasn't shown it up. All the cars I have worked on have had a separate electric fan on the condenser, I went to check the fan but there isn't one on this car (unless I have missed something) so how can it cool as well, or run as cold as others. |
These systems as col has said should be vacuumed completely and for at least 50 mins to make sure hey are completely empty/dry and nitrogen tested as a leak if it is small when you vacuum it can actually be sealed by the vacuum process i had a few issues with mine recently where the schrader valve did not fully close after the re-gas and we could find no other leaks so when you do a re-gas make sure the valves are either taken out in between the vacuum and re-gas or make sure they are not leaking at the end |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
I have a good friend that runs a car air conditioning company, he is the expert but talked me through the procedure and system as we went. As Col has said a proper regas means the system should be vacuumed down for at least an hour to remove all the gas and moisture in the system. Nitrogen was used for the pressure test and also helps remove any remaining moisture in the system. A small amount of lubricant oil is re-injected when the system was regassed which stops the oil seals around the system drying out. He did say it is recommended to be done as a 2 year service and as a rule of thumb most systems will lose 15% of their refrigerant per year so working on those figures mine should have lost 360 grams in 4 years and the actual figure was 400 grams lost so the maths wasnt a million miles away ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Can any aircon place do this?
Now this might sound a bit strange since Kwik-Fit and Halfords are two of the establishments we all love to hate but....
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
You can buy the kit from Halfords and do it yourself. Worked for me. Merc C220 estate Sport AMG
Thanks Paddi. If I let one of those places gas it up and it all leaks out later I guess I can have it fixed properly at the indi. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car. Spiffing wheel centre caps available |
