Home > Maintenance & Modifications > Supercharged cut out
sestorious
England 2008 Range Rover Sport Supercharged HST Santorini Black
Evening all, hope ure all enjoying the sun !
I've been to b&q and when I started the car it cut out. I started it again only for it to cut out again ? Third time lucky I was off. At some lights it cut out out and lost power. Got it started an yo my mate garage and the fault said fuel rail pressure too low ? We cleared faults an it's been fine since. No engine management light came on or anything so im a bit stumped ???
Anyone had this happen or can advise please ?
Thanks[/url]
Post #527258 Wed May 31 2017 5:31pm
TheWojtek
Your avatar says TDV6 but you say supercharged? What car are you referring to? Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #527266 Wed May 31 2017 6:19pm
sestorious
lol apologies I've been a member since my last RRS which was a tdv6.
I now have an 08 RRS supercharged 4.2 V8.
Post #527269 Wed May 31 2017 6:57pm
TheWojtek
Your fuel pump might be on it's last breath, that's the first thing I can think of. Regards etc.,
Wojtek
Post #527277 Wed May 31 2017 8:19pm
sestorious
Thanks for advice !
My mate says start with the fuel filter and go from there.
Do you know how to check the fuel pump please ?
Post #527287 Wed May 31 2017 9:13pm
TheWojtek
A clogged fuel filter would be safe bet as well.
Usually checking the pump involves removing it from the tank and checking the flow on a 'bench' (as in "anywhere you can spray a bit of fuel around") and measuring the voltage provided to the pump. It's not unusual to see voltage drop to 10-11 volts due to harness' age, while the pump is designed to run at 12 and while the car is running - around 14.3V. Any issues with the voltage will cause the pump to work at lower efficiency. Regards etc.,
Wojtek
Post #527365 Thu Jun 01 2017 4:13pm
Socast
Try getting the engine software updated, I had the same issue with mine, it was as though you start the engine and switch it off. I could get mine to stay running if I held the throttle down a little, but yeah, resolved with a software update Thumbs Up
Post #527640 Mon Jun 05 2017 11:00am
