![]() | Home > Technical > Cruise control problem |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5123 ![]() ![]() ![]() |
The forward sensor is on the left side of the bumper, in the "mouth" marked ACC ?
You can check that the ride height sensors are all working OK in the 4x4info screen - if there is a small red bar above any of the wheels then that is the dicky sensor, normally they would be showing white/grey 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Daveg Member Since: 28 May 2017 Location: Essex Posts: 2 ![]() ![]() ![]() |
Thanks Andy and Tim for the info, have found the forward looking cruise control sensor, all looks fine on the 4x4 screen so as suggested I will ignore the ride hight sensor. DTC code, just need the location of speed control unit |
