Home > Maintenance & Modifications > MY2011 Towbar Queries
Lunar_Lamp
2011 Range Rover Sport Supercharged Bali Blue
I want to hook up a bike rack to my MY2011 RRS, for carting around my road bike on occasions I wish to go further afield.
After looking at various options it seems that tow-bar mounted is the sane way to go, however I currently have no tow bar. What are the questions I should be asking to work out what I need to do to sort this out?
Is it just a case of buying a detachable bar and it'll definitely fit, or do I need to check mounting points? How do I check if electrics are in place, and are they needed?
I'm happy to fit it myself as I assume it's not overly tricky, but my knowledge about tow bars is basically absolutely zero, so don't assume I know the obvious stuff!
Post #526589 Tue May 23 2017 11:37am
Just a case of buying a towball off ebay.
Electrics and unlikely to be fitted. (remove the middle part of the bumper to see if you have sockets)
Depending on the size of the bike rack hopefully you will not require them as it can get expensive.
If required you could go for a cheap option, as its only a bike rack
http://www.rrsport.co.uk/forum/topic5581.html
Post #526592 Tue May 23 2017 12:05pm
Welshian
Wales
Hi Lunar this exactly what I did when I had my 2013 RRS, I now have a RRS2 which has a electrically deployable tow bar so I have one going if your interested at £150 including postage.
 RRS2 HSE Chile Red
1955 Morris Minor lovingly fitted every nut and bolt
Post #526598 Tue May 23 2017 1:06pm
