![]() | Home > Maintenance & Modifications > Bottom door skirts won't stay on with new clips |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9141 ![]() ![]() ![]() |
Mine is like this too and I've resorted to duct tape. It's only the ones on the front doors, the rears are fine. Mine are slightly damaged, however, which I've always assumed is the cause.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
The LR mod is to use 4 black clips (2 each end I think) which aren't 2 part clips.
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 ![]() ![]() ![]() |
Tried Velcro but the skirt is not tight enough to door frame to attach to, just tried upvc glue on a spare clip which seems to have stuck, was thinking of silicon adhesive between both parts, but was hoping for a LR solution to this, when I brought the clips the parts man said he had never heard of the problem. Is the LR mod available to fit and buy ? Thanks |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 208 ![]() ![]() ![]() |
The best glue to use is 3m Permabond or any 2 part structural adhesive. Holds anything together forever... 2018 Telsa MS
I purchased some copy parts off eBay recently and cheaply.
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 ![]() ![]() ![]() |
Hi
Part no. DYC500110
I saw those before but wasn't sure if they were correct as the ones fitted were a two part clip, could be worth a try, thanks |
The idea is you put them in the end positions so they don't come apart |
Ok will grab some and try them, thanks |
Standard response to any issue, sadly. LR dealerships deny that anything goes wrong with their vehicles and yours is always the only one that has exhibited those symptoms. ![]() 2008 TDV8 - it was a labour of love and is much missed |
