![]() | Home > Maintenance & Modifications > Broke down... black smoke, loss of power, won't start |
Worth checking the intake pipes as black smoke and losing power is often attributed to a split hose or poor fitting clip. Sounds like with the codes you have though that there are other things at play, but I'd definitely check the intake pipes as it's an easy fix. Wouldn't cause the car to stall I don't think though. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Check the oil level first...
